Problems with member database login
  • Problems with member database login
    getting the following error when logging into the database. has anyone had this issue? It happens after I accept the indemnity page. I then appear to be logged in but I told I am not authorised to access.
    Cheers
    Jordan
    Server Error in '/' Application.
    Sequence contains no elements
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
    Exception Details: System.InvalidOperationException: Sequence contains no elements
    Source Error:
    An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
    Stack Trace:
    [InvalidOperationException: Sequence contains no elements] System.Linq.Enumerable.Single(IEnumerable`1 source) +371 System.Linq.Queryable.Single(IQueryable`1 source, Expression`1 predicate) +590 ASRA.Controllers.NotificationController.Index(Null able`1 isLogin) in X:\Projects\ASRA\ASRA\ASRA\Controllers\Notificatio nController.cs:23 lambda_method(Closure , ControllerBase , Object[] ) +118 System.Web.Mvc.ReflectedActionDescriptor.Execute(C ontrollerContext controllerContext, IDictionary`2 parameters) +248 System.Web.Mvc.ControllerActionInvoker.InvokeActio nMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +39 System.Web.Mvc.<>c__DisplayClassd.<InvokeActionMet hodWithFilters>b__a() +125 System.Web.Mvc.ControllerActionInvoker.InvokeActio nMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) +640 System.Web.Mvc.ControllerActionInvoker.InvokeActio nMethodWithFilters(ControllerContext controllerContext, IList`1 filters, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +312 System.Web.Mvc.ControllerActionInvoker.InvokeActio n(ControllerContext controllerContext, String actionName) +691 System.Web.Mvc.Controller.ExecuteCore() +162 System.Web.Mvc.<>c__DisplayClass8.<BeginProcessReq uest>b__4() +58 System.Web.Mvc.Async.<>c__DisplayClass1.<MakeVoidD elegate>b__0() +20 System.Web.CallHandlerExecutionStep.System.Web.Htt pApplication.IExecutionStep.Execute() +469 System.Web.HttpApplication.ExecuteStep(IExecutionS tep step, Boolean& completedSynchronously) +375
    Jordan I just logged in ok.
    Regards.......Chook.
      I think I have sorted the problem now.
        Sometimes if I try to log in on my I phone it doesn't work?????? Seems to always work fine on the I pad and PC.
          after getting a new computer I have had to register again, all was good until I had to log on with my new pass word. it wasn't the problem as it turned out .
          in the log on box the first line one would think it would be for your user name and then pass word ,
          instead it required my e-mail address and then pass word. but nothing was there in the first line asking for such.
          old mate used to say NEVER ASSUME GRASSHOPPER.
            I hear your machine is up and running again JAL. how did it go.
