seat mounts
  • seat mounts
    Hi all, I need to replace one of my seat mounts 25 x 25 x 3 mm angle, as it is cracked through the bolt hole.
    5083 marine grade my be suitable and is quite common.Aussie Paul.
      G,day Elwynne, Give me a ring, I have some you can have, thats 6061 T6. Darrell Jones 41635175
        Elwynne,If the bolt hole is in the middle of the tube as I suspect, make sure you fit an internal anti crush tube so that the bolt doesn"t deform the parent material.Waddles.
          thanks for the replies, Paul, any particular temper in the 5083?
