If the dogs comen at you, the pliers in the teeth will suffice.It"s only if it"s run,n away you need Harry to stop it.
The ASRA By Laws
here is another example that is very successful. I made it up using an electrical lock out tag. just under the hinged tag is a sliding sleeve [ just happens to be there in the photo, actually fits over both. . so when the jaws are fitted around the control stick the sleeve is slid over the 2 tags and holds the jaws together around the stick. can be fitted and released using 1 hand. never let me down and I"d be surprised to see that it ever could .
