new frame design
  • new frame design
    came across this one. the guy obviously knows a lot about reducing weight on a gyro frame design , by drilling holes and also welding on critical areas. [ APPARENTLY ] Gyrocopter homemade, neues Heck
    Is this it Tony?
    Aussie Paul.
      yes that is it paul. thanks. only done the copy paste thing once before. never worked this time for me.
        Crikey - I’m nearly stuck for words. What a stunning exercise in irrelevant creativity. I wonder why the rudder cables cross over under the prop? This “gyro builder” is a rebel without a clue.
          Jeez what a differant concept? Gee it would be bouncy over ruff ground? Cheap motor replacement. Has any body seen a vid on how it flies?
            They will be able to call it the "whistler". Hope he has good ear muffs.
            Regards.........Chook.
              Justin, the engine looks like a Rotek EG4 0210. If that’s the case it is only 6hp so no one is likely to see a vid of it flying. (Which would be a good thing)
                yes tim, but remember its lighter now.
