I'll use this forum as a form of incident report and a warning notice to those considering using a SPOKED bicycle or scooter wheel as a nose wheel or mains.Don't do it, point blank
O NOT USE A BICYCLE OR SCOOTER WHEEL ON YOUR GYRO, THEY ARE NOT LOAD RATED FOR THIS APPLICATION.One of our members had one on his machine on an experimental basis, on pure coincidence and due to my only sometimes eagle eyes the member happened to turn his gyro into the apron from the strip from a final onto the runway, I was in the right spot at the right time [for once] and observed that his nose wheel twisted sideways when his machine bounced the nose while turning. We investigated when he came to a stop and had tied down, we found the spokes had all become significantly loose and that rim could move up to half an inch either side of centre. The brake pads [bicycle type] were buggered after about 3 hours of use and very limited use at that.Push bike and scooter wheels / hubs / spokes / rims are not load rated for what our gyros can dish out while under full power before they lift the nose wheel off the ground. Please do not use then for your gyro as you may suffer injury or death from so doing.The member concerned may file a report formally in writing at his earliest convenience and this notice will stand in its lieu. He has already sourced and procured a more solid arrangement to replace the scooter wheel and will fit it before any further flights are made.Regards,Nick.
