My thoughts on the tapered roller bearing, is that the tapered roller needs to be set correctly.... we all know what happens to front wheel bearings on a RWD car when the bearings are a bit worn or dry.... you can jack the car up and grab the wheel and feel the play in the bearing.... so you should remove the pin, undo the nut, inspect the cone, wash the bearings, repack the grease and reassemble.... then comes the tightening..... how tight? Ok, you nip it up lightly, spin the hub, back off, nip up again.... spin the hub.... then you go to pin the castle nut..... but it is half way between? So, you should get a thicker washer so you can pin it right, but most just tighten a bit more to get the pin in..... works on cars
So you do this on a gyro, imagine you have a gyro with the typical tapered roller bearing.... the only thing stopping the nut undoing (unless you use left hand thread) is the split pin and washer with the tang into the stub slot.... I am sure it would work, if the bearing is a bit tight, there might be a bit much drag to begin with, but shouldn"t be a problem.... should be good.Compare that to buying a $36 quality brand washing machine bearing and putting it in (correct way up if slot type) and torqueing the main bolt/nut to spec.
