Want some HP ?
  • Want some HP ?
    Jet Ski engines - Yamaha 1296cc 2-stroke EFI 3 cylinder165HP @7000rpm or 4-stroke 1052cc 160hp . Kawasaki 4 cylinder 4-stroke EFI 160hp Or maybe Sea-Doo , ROTAX 3 cyl. 4-stroke 1494cc EFI 215hp!!!![:0][][xx(]X
    I will ring around tomorrow for some weights , but the ones I have seen are a basic looking all alloy engine , the weight would have to be a lot less than an EA 81 or EJ 22 , & like Ken ( far-Ken-likethesoundofthat) said , go fast performance parts are easily available ( though I dont know why you would want to hot up 215 hp!) I might be barking up the wrong tree , but these engines are high tech & seem to fit the reqirements . EchoX
      And they have got really nice engine mounts and nice cushdrive setups. 2nd hand they are near impossible to sell and they loose a lot of value. But why not buy a new one, put the engine back in and sell as a new looking one with only 500hrs on it. Atleast it can't fall out of the water. What about the 750 Yamaha in a single seater. Only great minds think alike mate. Ken
        Bob Jumeau had one of these for an experiment before he decided to stop stuffing around and (I think) bought a new rotax.80 hp out of an engine near the same size as a 503, awesome!The problem with his was that it had a problem, he couldn't get it apart for some reason, seized with corrosion or what ever, hence the new rotax.Good luck with it if you go there.Cheers,Nick.
          Who is Bob Jumeau...?X
            Chainsaw bob... don't mess with him, he plays with nasty fuel mixtures too.He flies with us at Hunter Valley Gyro Club.Cheers,Nick.
              Chainsaw Bob? OK....sounds like a good bloke(?) I found a motor in QLD ...150hp twin cylinder 2-stroke near new, weighs in about 35 kgs out of a Polaris jet ski. Fitting a redrive would be fairly easy for a good engineer. The cooling system is self contained , meaning river or sea water doesnt run thru the block.X
                Hi Echo,One of the guys at work down here (Melb) has the 1500cc Sea-do jet skis you mention, I've asked him to get some specs from his mechanic re weight etc. His motor is supercharged and reckons there is a race version that has dyno sheets showing 330 hp.....Yikes...cheers,...Art...
                  G'day Art, long time no hear - partly my fault. 330hp...I reckon that would just about be enough!As Ken said new jet skis drop in value as soon as you pay for it so are a good buy second hand. My phone is 02 6573 1206 , ring with your number & I will ring back. EricX
                    echo take a look at artic cat snowmobile 900 twin it made by suziki water cooled, fuel injected 160 hp at 7200rpm at 5500rpm 95hp
                      Aint a helluva lot of snowmobiles around these parts - plenty of jet skis,but. Good one ,Benny, it seems there is a lot of high HP engines about if you look.See that Proair gyro has a Suzuki donk in it, be interesting to find out what redrive etc.
