Just had a little problem with my engine, in that the brass cog that runs off the crank to drive rotary valve/water pump shaft chewed out and then things stopped turning,[
!] the worst part is that i cant find a reason for it [?], both the bearings FEEL alright, the water pump was free same with the valve, is there any one who may be able to shed a bit of light on what has happened ?????Orr and i just thought that i should mention that i wasnt flying at the time this happened, so i dont need to lodge an iccident report, do i???Mark
