Does anyone know of a hollow prop shaft gearbox that will fit a EJ25 or EJ22?Want to play with variable pitch prop, which is controlled by a rod through the centre of the hub.RegardsBill
Hollow drive psru to suit EJ25 or 22
Found one. At www.suziauto.com. Based in Brisbane. Type 4 good for 220 hp. Looks like rotax box but beefier. Everything required to bolt straight up to a EJ25 or 22 for less than $3k. ;D
