ej20 and ea82 flywheel
  • ej20 and ea82 flywheel
    Had someone ask me if a flywheel, rotax g/box and adapter plate can be removed from an ea82 and bolted on to an ej20. I said i would ask on the forum on his behalf.
    The EA82 & EJ20 are different .The flywheel has a different stud pattern and size bolts.The adapter plate is also completely different. Also the Rotax box will be marginal to take the power of the EJ20. I would suggest you install an Autoflight or somethingsimilar for reliability. I have done many of these conversions and am happy to adviseyou on it.
      Thanks KEVT I wasn"t too sure. I"ll pass it on.
