Rotax 582......wat is the desired running temps of this engine....it's oil injected too, if that means somethingRuss....A1014 NT....gods country
Engine temps
Russ,If it's the Blue Head 582..CLYINDER HEAD.Max is 150 C. Normal is 110-130 C. The difference between cyl 1 and 2, max 10 C.EXHAUST GAS.Max 650 C.Normal 500-620 C.Difference between cyl 1 and 2, Max 25 C.All ex the Rotax Manual.Mitch.www.thebutterflyllc.com
My old 582(non blue head) and 532 normally ran at ~65.Common thought seemed to be that if you get over 80 in normal flight, land, you have a problem.Only in extreme circumstances, ie, long climbs on very hot days, etc, will it go near 80.It should always drop back when normal flight is resumed.Flying - The knack lies in learning how to throw yourself at the ground and miss. (Douglas Adams-The Hitch-Hiker's Guide to the Galaxy)
