circuit breakers and bus bars
Is this type of bus bar something which would do the job in a gyro or is there a preferred type?1 Photo
Just another consideration is to allow your separated avionics bus to be powered up without powering up your main bus. I do this to allow me to run radios and nav equipment for pre flight programming and situational awareness without having strobes, pumps, ignition systems and Hobbs meters running needlessly.
- 1 like
See attached Typical aircraft electrical systems.
This is a publication of Microair
- 1 like
I would like some ideas on how bus bars are wired with circuit breakers. Ideally reset breakers on the the panel in a self contained unit. Something like this from Jaycar but so breakers can be reset in flight if need be.
Tags: None
