Gentlemen,As it is possible that some of you do not subscribe to the service provided by Roatx regarding Service Bulletins, I am posting this information in the hope that those of you who operate these types of engines will be guided accordingly.Regards,WaddlesThe following NEW MANDATORY Rotax Service Bulletins have been released:SB-912-046, SB-912-046UL, SB-914-031, SB-914-031ULCHECK OF SUPPORT BEARING ON THE CRANKSHAFT AND OF THE BEARING BUSHING IN THE PROPELLER GEARBOX ON ROTAX ENGINE TYPE 912/914** Important Note!Rotax releases separate Service Bulletins for non-certified engine models. These service bulletins only contain information regarding the non-certified engine models effected by the service bulletin.Full service bulletin information and instructions are found in the certified service bulletin (without the UL designator).Owners and operators of non-certified engine models must download and review both the certified and UL versions of the service bulletin to obtain complete service information.These new Service Bulletins may be downloaded from www.rotax-owner.comThe following NEW MANDATORY Rotax Service Bulletins have been released:SB-912-047, SB-912-047UL, SB-914-032, SB-914-032ULCHECK OF ALLEN SCREW M8X100 IN THE CRANKCASE ON ROTAX ENGINE TYPE 912/914** Important Note!Rotax releases separate Service Bulletins for non-certified engine models. These service bulletins only contain information regarding the non-certified engine models effected by the service bulletin.Full service bulletin information and instructions are found in the certified service bulletin (without the UL designator).Owners and operators of non-certified engine models must download and review both the certified and UL versions of the service bulletin to obtain complete service information.These new Service Bulletins may be downloaded from www.rotax-owner.com
New MANDATORY Rotax Service Bulletins
