After 300 hours work, my amax redrive developed some bearing slop in the prop shaft so I decided to replace the bearings. That was a couple of months back and 10 hours ago on the new bearings and I began to see slop again recently. Pulled off the prop yesterday to find aluminium dust sitting between the outer bearing and the prop pulley. Cannot locate where it came from, what caused the slop though the bearings seem to have grown on the shaft and were a pain to pull off. Did lift the bearing seals but nothing appeared wrong. Need advice and or an amax manual with an strip down diagram and would appreciate help.Pete
