Sorry if this subject has been done to death in the past but will using Avgas 100 have any detrimental affect on a standard ea81. I have read a bit on it but cant pull a straight answer out of it.ThanksMark.
Avgas
G/day Mark,I bought Mark Rolles gyro (G767) which hasdone 1,095 hrs mostly on avgas 100 & i have continuedto use avgas since releaving Mark of his pride & joy.I am reliably told the Ea81 has never sufered any illaffect. Reacently a T.A. took "MY" pride & joy for a test flight & commented on how much "grunt" the motor still had considering the hours it's clocked up.Les.
Hi all,as les points out i had no problems with avgas in the suby motorBut...you are advised by some x/spurts..not to use a fully synthetic oil as it can lead to cylinder glazing...this is supported in the lycombing web site and also rotax say not to use a full synthetic oil in there 912 motors if you use avgas...The main reason i used it was because it is a far better quality of fuel,has a higher octane rating which removed any chance of pinging in a hot climate...has anti vapour lock properties over ulp...was redily available to me and i knew what i was getting.Please note that i did not get any obvious performance increases when i was doing thrust tests in the early days over premium ulp...but did gain around 4 % gain over ulp.The one down side is it will eat and foul spark plugs but as i replaced them every 50 hrs as a precation ..at $16.00 a set this wasnt a problem.cheers.PS...hey les i havent forgotten you...the rotor logs are still coming..or in the mail...soon
Mark refers to Lycoming and synthetics. It is apparently well known in the GA area that using synthetics in engines that have been run on leaded fuel is a no no.It seems that the synthetics mobilise lead deposits in the lubrication system, which then can obtruct oil passages.IMHO this is what happened to Wal's O 200 at Bond springs, the engine lost compression as the hydraulic lifters clagged up.John EvansThink logically and do things well, think laterally and do things better.
