I have available for sale a used MTV-7-F/LD 165-03 electric variable pitch constant speed 3-blade pusher propeller, with infinitely variable pitch range from take-off to feathering position via automatic or manual electronic control. It was used around 500hrs on a Lycoming 235 pusher engine. The prop comes complete as removed, with the spinner, slipring for 235 Lycoming, brush assembly, bolts, and a 12V plus a 24V P-120U manual and automatic pitch controller. The prop specs are 3-blades composite, 69†diameter, max power 160HP at 2800RPM. It has stainless steel leading edges. The tips are fine, the paint is chipped off, absolutely no dings on the blades surfaces, LE or spinner. The LE tape has perished, it will have to be removed. I"m not going to do a thing to this prop to dolly it up, best it is sold in it"s current condition.The MT specs are http://www.mt-propeller.com/pdf/datsheet/mtv-7.pdf, installation instructions http://www.mt-propeller.com/pdf/manuals/e-118.pdf. This is a LH pusher prop, not a RH tractor. It is a certified prop, I have the original invoice, shipping box, ARC, logbook, manuals, and all the green tags for the components when they were removed from the engine.Anyone interested? Perfect for high powered gyro"s.Cheers,Francois
MTV-7 composite 3-bladed pusher electric CS prop for sale.
