Seat tank
  • Seat tank
    Can anyone identify this brand of seat tank please?Image Insert: 81.42
    Daryl,Looks like a 40 litre Gerry Goodwin.
      A Ted minty I reckon.Geyy's had a bit of a 'well' for your ass.Ignorance is bliss............but only till you realise you were.Ingratitude stinks.......be generous carefully.
        Its the small Goodwin and the bolts at the bottom need releasing and re-mounting. The tank has already started to buckle up. Once the bolts are removed, put a weight on it and leave it out in the sun. When it returns to normal, re make the bottom brackets because the old ones will no longer fit.Tim McClure
          I have recently purchased a 60 litre tank from Gerry. He reccomends that you oversize the holds in the mounting point (not the seat) and have large washers each side. That way if the tank needs to expand and contract it can. L.Magner
            Daryl, it is a 40 liter Gerry Goodwin tank, and Tim is correct re the deformation. That's my ladder in the pic!!!![]Aussie Paul.[]www.firebirdgyros.com
              Thankyou one and all. Next question is, where can I find Mr Goodwin?Daryl Patterson
                In Sydney Daryl. I will email you his phone number.Aussie Paul.[]www.firebirdgyros.com
                  Nice ladder Paul.
