What size,
  • What size,
    What size and pitch of a wooden blade is suitable for direct drive ea81 turbo?I have available at a very good price a 64in / 20 deg will this be ok?
    Loaf,I have a 54" prop that was made by Bert Larkin for a direct drive Turbo EA81. I have since fitted a reduction drive so no longer require it.
      Thanks Rob,Firstly with this purchase I have scored a Reduction Drive was hidden behind the rags looks like 2.1 to 1, so will talk to Jack tomorrow.secondly how much would you want for the prop.Can you use mine at all?My prop is 64" and on the hub it has" 20 deg pitch to axis" do you know what this means and will motor with the Re drive do the job.
        Loaf,If you run a redrive, which you should, my prop will be no good as it will be too small. It was made for a direct drive. I have fitted a redrive to my turboed motor and am running a 68" 3 blade warp drive pitched to achieve 5800 RPM @ 6 PSI boost. A 70" prop would be better but I bought the redrive and prop together 2nd hand so it will do for now.A 64" 2 blade timber prop on a EA81 with a turbo would be way to small.Rob
