Here she is!
  • Here she is!
    Nearly done. Well almost.I have managed to cut the mast to short (#@#@) so will need to fit a longer one.Other than that all is going well.
    Looking good, and it has been a quick build. I see you have the calibration scale stuck to the mast, have you done a hang test yet?
      Yep, all was going well until I went to put the hub and blades on, only then I realised that I had cut the mast to short!!!New mast should be on in a day or two.
