It gets a little irritating when you hear this more times than not. I am mindful of kicking the tail around towards the transmit target because they can't hear you especially worse from the ground.. Ok one problem was wind sock and replaced it but that just caused distortion on Tx audio. The real problem i'm thinking is VSWR. I'm guessing these radios are being fitted in the MTO's without a VSWR test. Just having a standard antenna fitted. I used to repair emergency service radios and other transmitters and they were generally way out of tune in the final output stage. Civilian radios were set out of tune to reduce the out put to about 5W to 10W. this is because of the ACMA regs. The only way to really know how your radio is performing other than "I READ YOU FIVE" is to bench test with a Marconi bench lab and a registered test license. and i don't have a spare $50 K for this equipment. Secondly if you had a simple VSWR meter you could see how well your antenna is performing as they could be way out of resonant frequency bandwidth or impedance value out of spec and causing big return loss. I guess using 123.4 chit chat channel will give you an idea of how crap your radio is but until you bench tested it you aint gunna be able to do much about it. Our antennas are mounted inside the tail too. Yeah feel the pain. I'm also guessing the antenna connections could be crap and nothing like ingress of moisture ad coax cable loves it just soaks it up like a wick. Some rubber amalgam tape can keep the moisture out of connectors or some large heat shrink not as good but better than nothing. AHHH wish i was back on the bench i could crank hell outa my radio could talk to the aliens. And how many other radios out there sound like CRAP Hmm might have a niche market here i can see ye's lining up for a tweak. Seriously there seems to be a lot of sick radios out there Squealing like hell and not hetrodine x talk usually induced electrical noise and yeah i had an easy fix for that too or the IF VCO'S stage way outa spec. Anyway there's my radio ***** for the day... feel so much better now.
Mike.
Mike.
