chose a Suzuki Swift starter (very light weighs less than a Rotax), (CC,bevel on the right), the flexi plate (make?) is slightly dished hopefully to avoid a prop spacer, if I need a spacer I have an engineer that will be make one for $80, the bracket will be engine mounted not stressing the gearbox http://www.obbstartersandalternators...starter-motor/
I will send a photo on completion
