A year or so ago, at the Broken Hill field days I had a pair of silicon earlugs made, silicon is injected into the ear and you finish up with great hearing protection for $55 that doesnt hurt the ears at all, even after 10 hours with them in !!One thing wrong with them is that they are so efficient at keeping noise out that I had to have the UHF radio turned up to flat chat to hear anyone talk so its been a bit of a struggle in the hearing department. At the time I got the earlpugs, it was mentioned they had some sort of stuff to hook up to the earplugs to make hearing better but I wanted to make sure the earlpugs were going to do the job before I spent any more money!Anyway, about a month ago I sent my earlugs down to the maker and had wires hooked up to the earplugs, cost $ 145 or so, they plug directly into the back of the UHF external speaker plug and presto !!! with volume just cracked, I can hear perfectly[
][8D], even with just one earplug working as the lead is stereo and UHF's are mono. The UHF can be adapted to stereo if you want.I cant be more happy with the set up, very simple, cost effective, brilliant. So good to be able to hear so well!! I'm now going to get a MP3 player and aviation radio installed so I can have some music and entertainment when things are quiet in the air !!Earmould Australia is the name and the phone number is 0882515285. Ring today, dont put it off a day longer if you have a helmet with speakers and use earplugs.Get two pairs of earplugs done cause I'm going to get another set when I get the chance as I will use them around the farm and anywhere where noise is a factor !!! They come in a range of colours as well.Ps I'm not earning any commision [
]Brian
]Brian
]Birdy, It doesn't hurt a bit, will even help when the boss sounds off at ya.[
 33.38
 33.4
