Hi Sam,Sounds like the guys have made another great machine.
NEW 2011 GT Gyroplanes KRUZA
Sam,What"s the "dry" weight of the new style now? Do you know the weight of the engine alone?Hi BonesHere is a link to there updated GT Gyroplanes website, which has all the updated data.http://www.gtgyroplanes.com.au/Cheers SamL.............
Does ASRA keep records on these measurements when a manufacture registers a gyro type. And can we acess them?RegardsMattHi MattThe answer is yes, and it was captured to help people like you answer the very question you ask. My suggestion is to start with the ASRA register who I"m sure will be able to help.Regards SamL...................
Hi BonesHere is a link to there updated GT Gyroplanes website, which has all the updated data.http://www.gtgyroplanes.com.au/Cheers SamL.............Sam, i had not check it for awhile but now i have;Empty Weight 360kg WTF surely this cant be right?If that is right, thats only 30kg lighter than GB mod RAF, and it about 70kgs heavy that it can be, going on another machines weights.Last time i talked to them they were trying to lighten it?
Hey Sam, what are the standard avionics fitted?Looks like enough room for a transponder at the bottom underneath the CB"s and start switch. Can you confirm please.CheersBlueHi BlueThe 2 top decks in the centre console are transponder and then VHF radio. A bit hard to see but if you look carefully you can see the little 2 inch antenna fitted below the right side tank in front of undercarriage.Cheers SamL.....
Hi BlueThe 2 top decks in the centre console are transponder and then VHF radio. A bit hard to see but if you look carefully you can see the little 2 inch antenna fitted below the right side tank in front of undercarriage.Cheers SamL.....Cool, thanks Sam. Actually I was looking forward to doing an install again, has been awhile.What model"s are the Comm and XPDR? What model is the flat screen?I like the try fly buy idea though
