Eepybirds Videos (using Mentos and Diet Coke)
  • Eepybirds Videos (using Mentos and Diet Coke)
    I thought these might be found amusing and no they have nothing whatsoever to do with Gyros but they are amusing enjoy.Eepybirds Videos are here
    DG,Nope, nothing happened when I clicked the links...Nic.
      If you had Windows Nick it might have worked OK for you. It opened OK for me.
        If you are using a MAC or Linux you will need a Java Script engine installed as they are driven through JAVA goto "java.com" and install the version you need.Of course if you block java then it will nto work eitherHowever they are amusing to watch !!Link again just in case it gets lost in the chatterEepybirds Videos are here
          If you had Windows Nick it might have worked OK for you. It opened OK for me.Tim,I have windows, but only use it on a non-networked computer for not-too-hard stuff like MYOB accounts, or for stuff where I just can"t get a Linux Driver for a particular piece of hardware.
            Bull Gits.........I thought it was Billy Goats at Microsloth........
              Webbie,I"m sure I"ve called him lots of different names, usually unfavourable, usually when a crash occurs, mostly words the swear jar gets really fat on.!@#$%^&*(()))))Nic.
                Hey I don"t produce the videos.I only link to them! If your having crash problems then you need to look into your own system as the problemsorry but thats the way it is!Remember they are drive nby .js "java script"
