Mate just got a new style gps...........small as, light as, performs unreal things........like sending a message to a nominated email, telling em you have arrived at your destination Ok, they ( ya missis ) ;D can "plot" your exact course to your final landing spot, locates you to about 5meters, or sumin..................and a whole heap more shyte............unrealGoogle........."spot tracker", cost about $400 OzForgot.............check out
Latest gps gizmo
RussI"ve been using my SPOT for the last couple of weeks, 35hrs 3100kms, and it is fantastic.Also fully waterproof( so maybe Al could use one) and works well, just turn it on and it only takes about 5 minutes to get the message sent.( The instructions say 20 minutes but it only takes 5??)For those of you who fly to remote locations this is well worth a look.Ross B
Dean.........i"ll jump in.......ross will probably follow upYou compile the message, you select to whom it goes. Alternatevely you can elect to send it to their mobile ph.All done by the push of 1 button.Or.................you push another button, and it sends an emergency signal to the search and rescue dept. This signal goes for several days, locates you to about 5 metres.They can also plot your course on a pewtar.........start to end.It"s about the size of a pak of cigs...............brilliant little gizmo
DeanAs Russ described it has 3 main buttonsOK; Sends a message that you are OK. The email you get is as follows.
SPOT Check OK. Ross is on the ground and safe. ESN:0-7478359 Latitude:-23.5612 Longitude:145.3008 Nearest Location:not known Distance:not known Time:04/11/2009 18:20:09 (Australia/Brisbane) http://maps.google.com/maps?f=q&hl=e...UTF8&z=12&om=1
SPOT Check OK. Ross is on the ground and safe. ESN:0-7478359 Latitude:-24.833 Longitude:143.0615 Nearest Location:not known Distance:not known Time:04/09/2009 19:41:47 (Australia/Brisbane) http://maps.google.com/maps?f=q&hl=e...UTF8&z=12&om=1
.HELP: This means you have a problem and require assistance of your friends. Maybe used if you run out of fuel.911: This button calls the emergency services. The OK and HELP functions will send text messages to 10 people and also email 10 people of your situation.Check out there web site for extra info
I"ve been doing some other testing of my SPOT, and it is a good product.It takes about one minute from the time you turn on to get a message to your email and text message contacts.Tested it while driving in the car at 100km/hr. with SPOT sitting on the dash board.Ross B
Thought you"d be reeeeel glad to see the **** end of him for a bit. ( maybe, a long bit ) ;D
