Modifying a 40" Sea container to house a gyro
  • Modifying a 40" Sea container to house a gyro
    I was asked by a few people to share the topic of container vs. hangar on the forum.Please find attached a .pdf file regarding the topic.Regards,Colin
    I have to ask but why not use a HI-Cube container?They are about 600mm highr than STD container at 3000mm approxMind you they do cost a bit more though but might saved some workJust a questionit does look impressive though
      You are right, the Hi Cubes are higher, but the Magni"s are about 2.9m to the top of the hub bar and the inside diameter is too low.See attachement below regarding sizes. Regards,Colin
