Robert...There is probably a quick way to do it but I dont knowit..so Ill tell you the way I only know....When you have put in your "Insert an image file" put the curser directly in FRONT of..[ img ] Then backspace everything out. Then put the curser at the end and backspace till you get to [ /img ]JOB DONE.......Woz..."HE IS MORE MYSELF THAN I AM"
