JohnI have read the thread on Nicks gyro, and in order to acheive a (centre of gravity) forward of the Rotor thrust line (in a high thrust machine) you simply need a large enougth down loaded Stab that will react to propwash and airspeed in order to balance the slightly nose down movement of a high thrustline.This will raise the nose during power increases, and lower the nose during power decreases.The only penalties of such a design is it could take some time to get it right, there are some drag penalties due to the harder working stab, and a CLT machine will normaly climb better compared to a high thrustline machine.Now lets see if I get some heat about this. [B)]Regards Sam.[
