O'l mate and I just picked up a gyro not flown for 8 or so yrs. EA81 engine. Bit of corrosion. We had to virtually jump on the bar and sing a duet for it. The builder was a bit of a nurd. Used to do a computor impact study before going to the toilet. I'm at present stripping it to make it lighter. The dash contained an hr. mtr. - Exhaust Temp. - coolant pressure gauge - Coolant temp. - oil temp. - RPM - Altimeter - ASI - Manifold vacuum - Rotor RPM - alt and oil light - oil press. Fuel flow. Why the hell do you require a coolant pressure gauge
