Coupla points Rick, im thinkn he,s stretchn the effect of that small surface, unless he,s do,n 150kts.For any ground effect benifit from it, youd have to be touchn down at cessna speed.He " believes"??Dont he hava rotor tac?Sure test would be go for a lap as is, then take the wings off n go again.The difference in rrpms will give an accurate calculation of how much lift its producen.It may seem attractive, but wotever the payload/AS gain, itll only be at speed.Dont think that wot you can carry at 70kts is wot you can take off with.
