teeter bolt bushes
  • teeter bolt bushes
    anyone have an idea on how to get old bushes out of teeter block and tower on a mto,thanks
    Try calling Neil Farr at Autogyro Australia. He is listed under Instructors on this website.
    Waddles.
      There is a special kit for replacing both the teeter tower and block bushes. Neil from Autogyro Australia has one and I have made one for myself as well. Depending on where you are located, I may be able to help.
        To remove the bushes from the teeter block you will require a 9/16” tap. The process isn’t complicated but you will need a bolt to suit the tapped hole a nut to suit the bolt and some oversized washers. Happy to explain the process in detail if you like.
