Flight control specs.
  • Flight control specs.
    This was posted on the US forum. I had never heard of this arrangement, has anyone else?What are the limits to rotor head movement?Aussie Paul.[]Chris Burgess GYRO-CFIlocation: Frederick Maryland Posts: 140 Bensen made a reduced travel rear stop block for the longer hub bar, 34". It limited the travel from 9 degrees to 6 degrees. It was recommended for the longer hub bar to help keep the blades out of the ground. I had one but in my opinion, you can still hit the ground. By the way, with a tall mast, you can also hit the ground. None of these "crutches" will keep your blades out of the ground if you don't spin them up properly. Chris Burgess GYRO-CFIPRA #1680Frederick MarylandSnoBird Adventurergyrocfi@erols.com www.firebirdgyros.com
