Originally posted by jeff b
View Post
Emergency landing options
I'm going to get around to writing up the story of crossing Bass Strait in the Magni M24 for Gyro News. Yes, it's a long way over the water and I was pretty happy to see the top of Tassie come into view! :-)
G'day All,
Been thinking about this scenario for quite some time now and try as I may, I can't find any references that definitively cover the subject adequately. Maybe because no-one has had to ditch a gyro for real. Whilst I can reiterate my recollections of my unplanned close inspection of the Tamar river, it must be recalled that this was an uncontrolled crash. No input with the flight or engine controls had any bearing on the final flight path. So ..........
Upon realisation that no pilot input had any effect on the flight path, it remained to become aware of the rapidly approaching river surface and the inevitable contact that would soon be upon me. I managed to get a quick "mayday" out, but did not include position as I'd left the call too late. I know the gyro was nose down but was unaware that it was turning slowly to the left. I don't know what hit the water first, but due to the attitude of the gyro, I suspect it was the rotor blades at about the 10 o'clock position. I don't remember being thrown to the right hand side, but do recall my head hitting the water on my right side. Then, darkness. I had my harness done up, helmet and radio leads still attached at the time of impact. At no time did I consider detaching any of these. I became aware of cold water seeping into the helmet around my cheeks. I guess that's when I regained consciousness. I reached down and lifted the harness face plate which, due to the design of the harness, allowed all 4 belts to come free. Can't remember looking around for the surface, but likely went with the natural buoyancy of the body towards the surface, likely helped by lusty kicks as well. The radio leads detached themselves and I was not aware of any resistance offered by those plugs. How deep at this stage? Dunno. Maybe 3 M. On the surface, I orientated myself and struck out for the shore. I had plenty of time to think things out, like will I kick my gym shoes off. I decided no because feet get cold really quick. Similarly, the helmet. My diving days taught that 80% of body heat is lost through the head, so it stayed on. Actually, it supported it's own weight and was not a problem from that aspect. After that, it just got colder and colder.
So. There is little to be learned about water entry from that experience. However, with this in mind, if I had to ditch a gyro, I would never disconnect harness or helmet. Radio leads, maybe, assuming that the appropriate calls had been made. I would unlatch doors on enclosed cabins though. In my humble opinion, the ideal mode of entry would be zero forward airspeed with the rotor disc parallel to the surface of the water. The body angle is immaterial. I feel that to achieve this, it would be necessary to flare and slow at somewhere around 20' AGL because it is necessary to significantly increase the angle of attack of the rotor disc to achieve this situation. Flaring much lower would prejudice the clearance between the aft rotor disc and the water surface. If the disc hit the water, the gyro would immediately and rapidly roll/turn to the right uncontrolled. Assuming that one was able to achieve this attitude at the right time, the gyro would drop into the water and sink until the rotors hit the water. Yes, the pilot would still be strapped into this rapidly sinking, soon to be artificial reef. Once the rotors hit the water, they would twist off at the mast somewhere. The water resistance on the gyro airframe/body would be such as to preclude any significant rotation of it in the water when the rotors hit. Once the thrashing has stopped, the pilot releases his harness opens the door (if necessary) and floats/swims to the surface. Remember, allow the cabin to fill with water before trying to open the door. And all the time, our hero pilot stays cool, calm and collected as he plummets towards the bottom of the ocean.
In my opinion again, the recommended action of flaring and rolling to the right before water impact serves to lessen the rotational/turning force that will result from the rotors striking the water, as happened in my accident. It follows then that this will lessen the impact of the pilot with the water, or the airframe in an enclosed cabin.
Prevention is better that cure, so following the rules for gyros and over water flight, CAO 95.12.1 states that if you're over water further than you can glide to a safe landing on shore, the max distance from land is 25 NM and each occupant must WEAR a lifejacket and carry an approved ELB or PLB. The exception is trans Tasman crossings.
Just my sixpence worth.
Waddles.
Bert Hinkler used to tie an alarm clock around his neck and rigged it to go off on long water crossings if his head fell down when falling asleep. On another flight from the american continent to africa he took a small tropical monkey to talk to in an effort to stay awake. He took the monkey to England to live with his 3 legged cat but the poor fellow died of the cold.
I must say I have crossed some water and if I calculate that I wouldn't glide to the nearest waters edge I would count that time as 'dead mans time'. Calculated risks are of course sometimes necessary. If man never took them we would still be hunter gatherers.
One thing I would do is unplug the helmet from the jacks on the way down. I would keep my helmet on as long as possible, even after swimming away from the aircraft. The helmet would help keep body heat in longer as a lot of body heat is lost though the top of your head.
The last thing on my mind would be landing so as the machine is recoverable. Save your backside first, then if the machine is salvageable that would be a welcomed bonus.
Rick, I have been known to shortcut across the bay so I know what your thinking when you are low out to sea.
Point taken fellas, as this is all hypothetical my reasoning was that trying to undo a seatbelt in the panic of the situation may prove difficult not to mention the possibility of being knocked out during the event.
The image I have of this scenario is landing with zero airspeed flat on the water, laying it over to stop the rotor blades and then swimming away when safe to do so. All of that in a perfect world.
In regard to not flying over anything without a safe landing place, a pretty tall order for anyone that doesn't live in the country. From an instruction point of view though definitely the right advice.
If I was planning to do a long distance water crossing in a gyro I'd prob. wear a life vest, attach a marine beacon to my left side body, attach a miniture scuba 10 min. air bottle to my right side connected to a regulator. Maybe some small goggles on standby. If motor conks set off beacon and be ready to migrate to Reo. to avoid the $100'000 bill from the rescue services as you would be prob. breaking the rules. Almost forgot - if you survive the cold water if your down south, not to mention the odd curious white pointer.Last edited by mad max; 08-11-2016, 06:51 PM.
Does not matter if in a gyro, car, earth moving machine. Seat belt stays on!
When learning to fly a plane, emergency landing procedure is to
1). Set up best glide speed
2). pick landing spot
3). cabin check list, [one of them is, Harness done up and secure].
Also, when flying over water, if you are not within gliding distance of land, you should carry emergency equipment such as life jacket. [this is my wording]
[below is CASA wording]
Land aircraft that carry passengers and are engaged in:
(a) regular public transport operations; or
(b) charter operations;
shall be equipped with a life jacket or flotation device for each occupant on all flights where the take-off or approach path is so disposed over water that in the event of a mishap occurring during the departure or the arrival it is reasonably possible that the aircraft would be forced to land onto water".
Regards...... Ross
Rick, I am not sure about unclipping the seat belt before the blades stop. My hands would definitely be on the buckles ready to unclip when the thrashing stops. I don't want to end up outside of the machine while the blades are beating themselves to death.
emergency landing options . struth rick, yours are huge already, but I wouldn't be following your "into water procedure", I really need to think about this a bit.
remember me saying my seat and seat belt was my "safety cell", your also saying waiting for the rotars thrashing around, to stop and swim away.
no seat belt on before you touch down and the rotars thrashing around when they hit the water [ besides the fact that you want the rotars to hit on the right side first which will start the thrashing around earlier ] = trouble with a capital T.
in my humble opinion anyway. because I thrashed around till I lay flattened on the ground.
we have seen gyro accidents and because of some home built ideas, the seat belt brackets have been " light " to say the least. broken seat belt brackets have equalled death in some accidents . slightly stronger brackets and bolts would be only be a few extra grams at the most, so there is no excuse for too light seat belt mounts etc. that's why ASRA have specifications on mounts and angles of seat belts over shoulders and the retraining force they have to be capable of .
that is what is needed at the time crashing. that's all at the time of the accident/crash. "have your seat belt on"
taking off your seat belt would never be on my list.
I could check my seat belt buckle before I touched down that my shirt or coat that I could be wearing wasn't in the way. although that would change when everything got wet or any thrashing around anyway.
it could be interesting that we could ask ASRA for a crappy old nearly never going to fly again gyro, hang it from a crane over a tank ,even no engine on the back but just a counter weight for correct balance , some how spin the blades up and drop it in the tank to see what happens to the thrashing , the test tube dummy pilot strapped in etc etc . it would be our very own aussie myth busters..
if anyone was going to ask asra, I can tell you the answer after another short story.
after 2 lives were lost recently about a year ago when a tandum crashed into bushland, I spoke to ALAN WARDILL, about should it be taught that pilots were instructed how to put it down in trees, don't quote me on word for word but ALAN said " we teach pilots not to fly over trees" [ politically correct perfect answer too obviously alan ] and I respect him for that , but could they have lived if they dropped it and never had forward speed.[ I don't know if they did or didn't had forward speed ] which side is preferred for the rotars to hit etc etc.
so I think asra would respectively say the rule for flying over water is ............this is the minimum height and distance..
that's a hell of a long way out to water rick, I can see why and what would be going through your mind.
I have been thinking about some sort of air bag inflation devices like in cars . but they stay pumped up . how much weight in that. ..
memo: ring patent attorney in the morning..
My advice is to not cross any water unless you have the balls of Bert Hinkler. Always maintain a glide angle to the high tide mark, and in my area I would glide to the mangrove edge, flare in and pray the next few tides are not big ones, then urgently load my .44 mag. before gingerly wading up to hard ground.Last edited by mad max; 07-11-2016, 07:37 PM.
My strategy for putting down in water would be to land as slow as possible with my seat belt unclipped, roll it to the right as per Birdies advice which should hopefully keep all of the blade slapping behind the gyro wait until the mayhem stops and then swim away. Sounds easy, but add adrenaline, sheer terror, the thought of losing your machine and I'm sure it would not be that simple.
We fly a route down here in Sydney called Victor one which takes you past Sydney heads and under the main flight path into Sydney, there are parts of this route that have to be flown about 2klm out to sea and must be flown under 500 feet above sea level, flying this route puts this discussion into a whole different light.
I have thought about Allan's swim a few times too, as there are a few rivers and creeks that I cross. I do remember that he never had or very little control with the stick, but if it was an engine failure I would want to drop it flat I'm sure.
take a big deep breath before I "touched down"
my feet would be down nearly 2 mt by the time the rotars hit the water , until the rotars hit it would be going down fast, but for a second or two would be slowed up with the rotars hit the water and bent up. even when they hit at full flying speed I recon they wouldn't even do 2 complete rotations . hopefully less than 1 actually because I would want to be coming up through there. as soon as the machine and me was wet I would be getting the seat belt off and pushing up with my feet first .and also hopefully pulling down at what's ever left of up the rotars . pushing with my feet and pulling with my hands that hard that my radio cables could come with me or stay behind .
watch for the bubbles. swim up.
a long time ago when back inversions machines came out , I had always wanted to try one, I was some where, where they had one in the garage , when they strapped me in and tipped it backwards , I was only there for a while [ not even tilted all the way upside down ] when my head started to swell with a slow rush of blood , and it got to be uncomfortable ] as I was only trying it I decided I didn't like it and I asked to be tipped the right way up. I also wanted to help and also speed them up.
as it turned out I was tipping one way thinking I was heading in the right direction and I could tell they were pushing the wrong way. WTF are you doing , I want to get up so let me up.
then they said, I was trying to tip the wrong way and stop pushing, and they would get me upright. struth I really had "up" the wrong way . I was trying to push myself further around and down. dead set head spin of an experience. and a good lesson learned .
SO I'D ALSO SAY WATCH THE BUBBLES. cause they will be going up and that's the way I want to go too.
I think timing , or not loosing time at the start would be critical , but not to start too early as the seat belts and safety capsule of the strong seat tank is always an asset.
as I'd said I'd thought about it a bit but if any one can point out some constructive errors please say so.
