Almost an incident.
    Thanks for another episode of "great moments of engineering magnificence" (or better crank my soap box up another couple of thou)Having many years at BHP I learned one thing,make sure that you have a picture when you are describing something to an engineer, otherwise he will end up more confused than someone who doesnt know much.Im not back, I just never went away,Mark.
      Which would be you...
        Just curious,Why make it necessary to log on to read the accident/incident section.?
          mrfordThinking same,With all the stuff this last week on every other post, not just here but the good ol usa,i wuder way i botherboundry rider
            I will try to post some pictures of the last hub bar failure.Image Insert: 66.29
              Tim,The polished bit was the first?Nick.
                What blades do we have here.......RussLook same as mine.....sh.t[xx(]RDC
                  tim they look a lot like early pattroney's????????????
                    They look like Patroneys except the ones I have [2 year old], havent got the hub bar machined down.Not sure if Tim is still home, I will try and ring him and find out more info.The pictures are prett scarey !You never know how far you can go, till you get there !
                    • #25
                      Yes, early Patroney's.Tim McClure
                      • #26
                        Tim,Do you have any high resolution photo's of the hub bar.Looking at the image, if you look at the edge of the break all round the perimeter of the break you can see a dark and slightly polished line, this could be the 1mm damaged section I've referred to which is a product of machining. I'd dearly like to see a full screen high resolution shot of the ends of the hub bar to have a good look at it at better magnification.Cheers,Nick.
                        • #27
                          Had you have gone to Cooma, You could have picked them up, turned them around, and looked at them up close, in high resolution.
                          • #28
                            Yes Mark,It seems the fish saw me coming too... Never mind, I have a new manifold and belt drive going, now for the mast and prop, etc..
                            • #29
                              Good on yer Nick
