Allan,
I am attaching a picture of the MLS with a red graphic line indicating the line a break would likely take if it were to do so.Please note, trim spring would still be in place and so to are the pulley straps either side.I do not believe the MLS unit could make it"s way into the prop, whilst attached at three points to the mast.The prototyping of the Patroney Blades on the Monarch MLS system required the installation of 1/8" thick teeter stops, so as to give clearance to the underside strap bolt head from the top of the MLS Bendix housing.If the norm for a Bensen head is 6 degrees of teeter either side, then the new teeter stops have effectively reduced this amount. By what? I am not sure till measurements are made. It could be in the order of 1-1 1/2 degrees. Thus the amount of available teeter may now be 4 1/2 degrees. Whilst approximately +-2 degrees is required for normal flight, I find it quite conceivable that during a negative event, rotor rpm could decay enough to cause the blades to teeter more to try and equalise lift.Now the available amount of teeter may be 4 1/2 degrees, however if the strap bolts are inserted from the top, the amount of thread, fat nut and double 0.0063" washers is considerably more than the clearances allowed for during the install of the teeter stops and original prototyping. Perhaps as little as 3 degrees would have been available, before the thru bolts on each strap may have contacted the MLS housing. As each bolt thread and thick nut have impacted, the MLS Bendix housing on top of the MLS unit would have taken an almighty hit, twisting the housing to the right and impinging on the large flywheel. This may have bitten in more and more reducing blade rpm dramatically. The induced friction now causing the airframe to rotate to the LEFT.Brian I think you might agree that S & L in a blustery 30 knots of wind with those bolts swinging past the MLS housing with the bare minimum of clearance, is a little closer to the limit than even you might like.? If the blades are slowing, they are not generating the lift, the gyro is dropping rapidly.As the blades are no longer flying, the gyro noses over. Look at the angle of your gyro in a hang test.Once the blades are no longer flying, stick inputs are likely rendered useless and unresponsive.Someone recently said if you were doing a vertical decent, left spiral, the stick can feel like it is unresponsive. This is hearsay and I personally have never tried it.Anyway Fellas, I don"t think the torque tube broke off at all. I don"t believe there is any inherent problem with the Butterfly Monarch design. I also don"t believe a push rod/rod end let go. Although it is speculation, I am almost certain given Allan"s account, eye witness accounts, (both of whom have seen me flying locally on a regular basis) and several high hrs gyro pilots views, that the visual and audio recollections of all coincide quite reasonably with Allan"s account.As Doug Riley on the US forum says, there is a fair hunk of metal hanging off the rear end of the torque tube, however it is supported by the push rods when the head is off the rear stop. Each average push rod able to carry some 200 lbs in compression. The torque tube is rated and engineered to handle much more than that. Also this torque tube is not a std Bensen tube and the manufacture claims it is indeed stronger. I will be flying my Monarch with complete confidence as I did during the ASRA 2009 Tasmanian National Championships.
