Rotorhead and ext. Blades.
  • #16
    Mark,I have found a way to stop the Sqweeky, ticky kind of noise I used to hear from my rotor when patting them up.When landing in a rough paddock, Do a forward sommersault in your Gyro when the rear Shock collapses. This will put a 45 degree bend in one blade only and break the tail off your gyro!Sure stopped the rotors sqweaking!!!Ps the new ones have been ordered from Jeff.Marcus.
    • #17
      bugga
      • #18
        quote:Originally posted by Mark HoranMark,I have found a way to stop the Sqweeky, ticky kind of noise I used to hear from my rotor when patting them up.When landing in a rough paddock, Do a forward sommersault in your Gyro when the rear Shock collapses. This will put a 45 degree bend in one blade only and break the tail off your gyro!Sure stopped the rotors sqweaking!!!Ps the new ones have been ordered from Jeff.Marcus.[:0][:0]....[][]
        • #19
          Mark.Is this what you ment?I went and tried what you said, sure did stop the squeak! The problem now is with these boomerang rotors I get great lift but I get about 500m from the strip and my gyro turns around and lands me right back where I started from. Any more sugestions or help?GraemeImage Insert: 56.57
          • #20
            G,I don't know about you but I'd be suing him for negligent advice, it should be worth about $3m.Good luck,Nick.
            • #21
              Good one Nick'eddMark.
