mast height
  • mast height
    ok just pulled my engine and while i have it off i'd do couple of things one is to raise the engine the air- command clt says i can turn a 68inch prop and have a 62 on it now. next when the conversion was done i have some extra holes in the mast that do nothing so i figured i'd replaced the mast while i'm at it. next i have made a tall tail for it. and powder coat is next. what i could use is some advice on the mast. i'd like to raise it some but dont know if it will change the cg or the way it will fly. i have been tolded by a friend that the only differents between a kb2 and a kb3 is the mast on the kb3 is 10inches taller. so what i'm asking is can i raise the mast if so how far 2,4,6,8,10 inches and things would still be allrightthanks ben
      dave i really appreciate your answer thanks again ben
