The fitting on the bottom at the sump, snagged. (Kept turning ther fitting moulded in the plastic.)
Called me Mate, who called his Mate.....cut it off and pull it out or knock it in.I chose to knock it in.There is about 1/2" wall thickness in the plastic sump section.Today, I purchased a variety of brass fittings.Tomorrow Pirtek will tap in a 3/4" reducer to take a 1/4" piece which will accept a little bleeder.Fuel lines fitting to be installed adjacent to the sump bleeder.This up grade to a 10 gallon tank has been problematic...required a longer control stick, new throttle quadrant arrangement, mounted off of the new steel frame for the seat tank.Be carefull with the sump fittings on old seat tanks, add some fuel, which may help lube the fitting and free it before you do what I did..... >
Two days turns into fiveMitch.
Well at least it doesn"t leek.
