Right its 10 in the morning and i feel like a drink already, cept i got to fly this arvo damn it.What is a good way of cutting 6mm allu plate, as i tried a jigsaw, was kind of successful but it leaves marks on the plate where the skids are jumping around, and the teeth of the blade are blocking up with melted allu
Cutting Allu plate
Radial / compound saw. But make sure you get a blade suitable for alloys. They generally have many more teeth and are more expensive than the wood variety, but well worth it. Nice clean cut and no clogging. I also spray the alloy and the disk with cutting oil just before the cut.
bones thanks for the e mail awhile back. correct you wouldnt have the work for a suitable size plasma. power saw with an ally blade will last you a life time for straight cuts. to cut curves or shapes you can use a jig saw and have sucess. buy the good blades and a good saw also a good cutting compound, a grease type one is best because you need to put it on the UNDER SIDE of the plate because the blade cuts on the up stroke, this is when
[ or call Rosco]
