G'Day Gents,Have all the necessary bolts to replace pitch block bolts, pillar block bolts and blade retention bolts.The Pillar Block on Hub Bar is slightly skewed, in other words it's not exactly flush with the edge of the hub bar, there seems to have been some twist over the years. These Benson Blades and Hub Bar were manufactured back in 76'.Questions I have are:-1. Any special technique for marking current position of pitch blocks as I replace bolts, for instance, If I remove one old bolt and install a new one, before doing the next, will this maintain the pitch setting????2. Do I try and set the Pillar Block (hub) flush with edge of Hub Bar??3. Did the benson hub get glued as well?Any advice welcome.[
]Cheers.Mitchwww.thebutterflyllc.com
