I have to lower my keel by about 90mm to make clearance between it and the prop. The problem i have come across now is that the tail wheel is too close the the ground. >Any ideas on raising it again, or has anyone else had this problem. ??? Cheers Matt.
Lowering keel
I have to lower my keel by about 90mm to make clearance between it and the prop. The problem i have come across now is that the tail wheel is too close the the ground. >Any ideas on raising it again, or has anyone else had this problem. ??? Cheers Matt.Matt, when I did that to RAFs I used plates and angled the rear keel up to keep the tail wheel at the same position. I did a couple of Roscos like that as well.Aussie Paul.
