I am just about ready to hang my machine to check it's degree's nose down hang.Question, Can I use a fork lift to lift the machine from the hub bar ?Orshould I make up a lifting block to be used with block and tackle ?My rotors are Jack Allan with 3/4 inch hub bar.The machine is an open frame fitted with Rotax 582.The machine below is not mine, its just an example of what I am thinking of doing with mine. Regards Sam. [?][?][?]Image Insert:
61.97 KB
