Hangum High
  • Hangum High
    G'Day MatesWell This past weekend I hung the little gyro from the rafters in my shead.It is a modifyed Bensen to clt so it has a rather tall gear.The mast angle came in at 0*. and the foward keal came in at 9* nose down.When on the ground the keal is leavel or 0* and the mast is tilted aft 9*.My guestion is,is that good bad or ok.Also I am needing info on the rubber shock in a Rosco nose gear.How tall is it,how soft or hard is it,can I buy one? Thanx GentsSonnyIntelligence is not a privilege,it is a gift and should be used for the good of mankind.
    Hey Sonny,Check out Sam's thread on hang test, then do a search, there was plenty of info and discussion some time back. Should get everything you need. See Ya.Mitch.www.thebutterflyllc.com
      Thats perfect Sonny, given you hung it with half a tank full of juice.Sam. []
        Hay Sonny ! bet you didn't have your helmit and boots on did ya ??? heheheheheBob...
