I thought that I would try and install a fuel gauge so that the fuel level could be monitored while flying (as apposed to try and look at the sight glass along the side of the seat tank while flying).
I do use a timer, check fuel level before flying, and allow for 1/2 hour reserve fuel by the time I return.
I purchased an ultrasonic transducer for less than $30, and an Arduino (from China) controller.
When testing using a couple different plastic jugs, this worked.
When I connected to the fuel tank on my gyro, I am not getting a reading. As the base of the seat tank is not horizontal, I thought that maybe as the signal is going through the tank and bouncing off the fuel level, the signal will not be redirected back to the transducer. So I cut a bit of aluminium bar at an angle to make a wedge so that when I stuck the transducer to it, it would be perpendicular to the fuel level.
Still no luck.
I thought maybe rotational moulded tanks may not work, so I attached to another seat tank stored in my shed. This worked.
Not sure why not working on the tank on my gyro.
Still no luck.
