Hello to everyone and a merry Christmas.
I am a new member to ASRA and I am still feeling my way around this site.
I am in the process of building a side by side gyro that is based on the style of the cockpit of a Robins R22 chopper.
I would be happy to place a photo or two as the build progresses if anyone is interested. The build is approximately 60% done.
I am rapidly getting to the point where the main rotor assembly needs to be setup so with this in mind, I do have a question that I just can't seem to find the answer for. I will do my best to phrase it correctly.
With respect to the main rotor blades, is the RIGGERS ANGLE (angle of attack with respect to the hub bar) set at any particular angle. IE: is there a 1.5 degree positive angle of attack on each blade with respect to the hub bar or is it 3 degrees + or 0 degrees????
Any help with this would be greatly appreciated.
