G'Day Gents,Tims advice on cutting back the gel coat on my tail repair, led me to call Rob Patroney for advice. Which in turn led me to tackling the easier jobs first. I have repaired instrument pod and face plate back to original condition for use as plugs to make molds. I have popped my first mold this morning.The mold is a lot better than I expected and will require only a couple of little blemishes to be filled, then polished up with wet and dry and polishing compound.I am using cloth, mat, polyester resin, talc and black colour for the molds. Parting wax and a PVA liquid. Even with a rough sanded parting board, 7 or 8 coats of wax and PVA the mold popped easily. Here are some pics.MitchImage Insert:
60.1
60.1
]Mitch.Image Insert:
48.28
] that mold will now take it's place on the 'wall of shame' in my workshop. That mold popped off the plug easily, due to the fact I had liberally brushed on the PVA solution. I had tried rubbing it on with a rag and found it troublesome when it gummed up whilst forming a film. Anyway, because it polished up like glass, I only gave it four coats of wax (which was probably enough) and wiped on the PVA with a rag. Did not get the same result as brushing and basically destroyed the surface of the mold whilst trying to put out the first part. They stuck in places. Quicker to make a new one than repair.Anyways, today I made another mold and tonight I am waxing up the instrument pod plug, so tomorrow I can have a go at making a face plate and doing the bigger more complex mold.Fingers crossed.Mitch.
53.18
