Hello everyone,After completing my first Gyro fitted with a Rotax 532 which i had to buy a new exhaust system for ,it has no power from 5000-6000 rpm ,narrowed the problem down to the exhaust system by opening one of the flange joints slightly to relieve back pressure.I know this is not recommended on any 2 stroke but I got sick to death of changing jets.The vendor of the exhaust said to send the muffler back and they would replace it but after doing a few measurements i think it might be the 90 degree bend shortening the expansion chamber.It only measures 5" from 1 end to the side ,the specs say it should be 6 and 5 eights. Is there any body that can measure there 532/582 90 degree system and let me know the correct lenght of the 90 degree elbow connected to the y pipe. Any help would be very much appreciated. Peter Adams
532 High End RPM Problem
Thanks Murray,the carbs are new,new points,egts both read 950 with standard jets and i have tried different jets with no joy .I even dropped the pitch of the prop 1 degree from reccomended.The only thing that makes any difference is relieving backpressure.The engine runs and starts very well.It will run to 6000rpm but it is very slow in pickup and uncontrolable between 5000-6000rpm .The engine runs very well with the joint open as shown in the photo below.Image Insert:
81.37
Peter, have you got a photo of the outlet end of the muffler and has the muffler been modified in any way? If the mixture is too rich it can cause this problem, especially with a long heavy prop. What is the prop and what is the length and pitch? Your EGT readings suggest too rich (unless they are in C, then it would be too lean).Tim McClure
Tim, The prop is a 3 blade 64" brolga with 13degree pitch blocks it was 14 degrees. Just spent all afternoon cutting my new exhaust to pieces ,What a job,and opened up a few baffle ports with the drill.My egt's now showing a bit over a 1000degrees and I have full control between 5000-6000 but 6000 is the max it will rev to, so yes now the muffler has been modified[
] and my chance of exchanging it at Bert Flood is no longer an option.I run 50:1 premium unleaded mix and although the egt's are only showing a bit over a 1000 the plugs look a bit on the lean side,so yes Paul I might still try a 40:1 mix just for interest sake.
G'Day Peter,Did you buy Rod Martin's gyro and change out the 503 for the 532?Hope you get your engine sorted. Sure is a nice gyro that one of Rod's.Cheers,Mitch.www.thebutterflyllc.com
950 degrees EGT is way to low. You are loading the engine down to much with that amount of pitch. Ideal full throttle readings are 1200*,although I would accept lower than that when static as engine RPM and EGT's will increase in the air.Aim for about 6500 RPM in a full throttle climb.
G'Day Pete,Mate touched base with Jamo last night, he bought me up to speed on your progress and gyro. Congrats and Safe Flying as you approach Solo. Hope to catchup early in the new year. Cheers Pete.Mitch.www.thebutterflyllc.com
