Help! Cables....
  • #16
    If thats all it took to make it rain, Birdy would have whipped out the brasso years ago!
    • #17
      Maybe he's scared it will flood, washing that machine would do some seeeeerrrrrriiiiiouus damage to the environment, need a 1/1000000 storm to wash it all away...Cheers,Nicholas TomlinAlarmist - www.alarmist.com.au - we scare for you
      • #18
        Motobike shops are good sources of the coiled wire outer cables and usually sell it by the meter from bulk rolls.PeteBairnsdale,Vic.
        • #19
          I think Birdy thinks a bit diferently about WASHING stuff than most of us, You know, its like emergancy measures only ! pluss thinking of the Feral as a farm impliment has extream advantages too, I mean , ya don't have to wash a tractor.... or wax the backhoe , so why would ya do that fer a flying do-gizzie ? the problem is simple .... its a Priority thing ! well theres priorities and then there's Priorities ! ya see !!!! hehehehe We're hurrassin ya Birdy ! stand up and defend yourself ...!Bob..." Momm'a alwayse told me , Son the impossable is only a little bit Harder... and ya know I do believe She was RIGHT ! "
          • #20
            quote:Originally posted by pbradleyMotobike shops are good sources of the coiled wire outer cables and usually sell it by the meter from bulk rolls.PeteBairnsdale,Vic.The coiled stuff that Raf uses is not that good for turning corners and staying light and smooth. The best I saw was on a modofied Raf in NZ, RAE. They has used the outer from boat stearing cables. The outer is made similar to the inner around the teflon, and I could not believe the difference in stearing that machine after they changed the outer cable.I will be using that type on Firebird after that discovery.Aussie Paul.[]www.firebirdgyros.com
            • #21
              Speaking of cable and cable types, where does a person find heavy cable of the type that they use in the Wounderlitch pre rotators ? sort'a a big weed eater cable...that kind of cableing big and small can be quite usefull on a gyro, like trim adjustment with the knob where YOU want it... or choke levers even richness adjusters !.... I have looked arround but it seams they are very hard to find ! anyone know where to look fer those type of cables and what their actually called ?thanks !Bob....." Momm'a alwayse told me , Son the impossable is only a little bit Harder... and ya know I do believe She was RIGHT ! "
