Hello guysIf you had your drothers and were skilled in steel fabrication as well...what would you build from scratch this time around? bearing in mind that you have about five grand to purchase all steel and sheet,fittings,gas bbq,small gen set,solar shower...you get the idea.In particular...ease(or as easy as it"s possible to get)of rotor blade handling and in particular,suspension.Something other than the rigid dual axle things you see on most trailers.Or do i just knock the **** end out of a caravan?
Peter
Peter
Cheers, Mitch
