Gyrocopter Electrician required
  • Gyrocopter Electrician required
    Can anyone recommend a gyro friendly auto electrician or wiring guru in Sydney with Subaru EJ 25 computer experience?I"ve approached most of my local guys only to have them run in the other direction or give some lame excuse when I mention the "G" word. I think my problem might not be too complex as all the wiring loom is there but some of the engine sensors are not showing on theSkydat panel. The engine starts and is running fine but just no temp, oil pressure, tacho, etc on the display. Any help appreciated.Hoges
    Just buy simple after market gauges from Super Cheap Auto and you;r good to go.
      Highly recommend Andrew Rickard 0417 497 108He works on all my "weird" stuff.Active glider pilot too.top bloke.Tell him I sent you,cheersArt
